do the 88-92 engines have provisions to run a mechanical fuel pump?
Old Aug 2, 2005 | 10:46 PM
drptop70ss's Avatar
Car: way too many
Engine: 283s to 454s
Transmission: autos and sticks
I have noticed that my 88-92 TPI engines have a blockoff plate where the mechanical fuel pump would normally go on the block. If I converted to a carb setup can I just install a fuel pump pushrod and a standard small block chevy fuel pump? Do I need a bronze tipped or special pushrod with the later roller engines (what year did chevy switch to rollers anyway?)
Old Aug 2, 2005 | 10:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Rollers started in 86. The factory cam might not have the fuel pump lobe on it.
Old Aug 3, 2005 | 07:02 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
asfaik, roller started in 87 and the blocks and cams have provisions for mech fuel pump.
Old Aug 3, 2005 | 07:08 AM
drptop70ss's Avatar
Car: way too many
great, thanks for the help!
Old Aug 3, 2005 | 07:34 AM
brutalform's Avatar
The earlier of the 82-92 blocks came with a blockoff. With the later blocks, you could not even bolt up a mechanical fuel pump if you wanted to. The mounting pad is there, but its not machined with the proper holes.
Old Aug 3, 2005 | 08:47 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
This is true,SOMETIMES.My 96 pickup has no hole or lobe on the camshaft for the fuel pump.However,my wife's 97 Tahoe DOES have both the hole and a fuel pump lobe.I know it's wierd,but GM always was good at throwing curves,especially if they had wierd parts in stock.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
