Things to check when replacing heads?
Old Aug 5, 2005 | 02:25 PM
dsherw00d's Avatar
Car: 68 Camaro, 73 Nova, 67 Mustang
Engine: 350, 355, 289
Transmission: Muncie, 700R4, C4
Looking for some advice. My 88 IROC Vert TPI needed the valves redone. I decided to buy stock rebuilt heads with the same castings instead of removing mine and waiting for them. I didn't want aftermarket or performance heads. Motor is stock and I dind't want to put much more stress on the components. It reads 56K miles, but not way to verify this. It doesn't look abused though.
Question is - are there things I can check with the heads removed to tell how healthy or not the bottom end is? The piston walls look nice and there doens't appear to be excessive wear. What about piston movement? I can notice a very slight side-to-side movement, an no up down movement without moving the other pistons. I'm planning on borrowing a inside micrometer to measure the bores and make sure they are round and in spec.
What's the best way to clean the valley and if any of that built up sludge gets lost inside will it hurt? I'm planning on running oil trough it and changinf it before turning it over.
I'm using the factory style metal head gaskets, should I use a gasket sealer and if so what's a good type or brand?
Thanks,
Dan
Old Aug 6, 2005 | 05:45 PM
Vader's Avatar
A little piston movement is normal.
You might want to check the ridge, clean the deck thoroughly, and inspect lifter condition while the intake is off.
You can clean up the valley with a mild solvent, vacuum cleaner, and rags.
specialized
Jun 18, 2022 09:26 AM
italiano67
Dec 11, 2016 09:21 AM
justin57
Aug 20, 2015 07:05 PM
Bob88GTA
Aug 18, 2015 03:31 PM
mizz0313
Aug 12, 2015 06:45 AM
