Fuel Filter Part # (LG4)
Old Aug 9, 2005 | 12:51 PM
ZMonte85's Avatar
Car: 85 Monte Carlo SS
Engine: modified ZZ4
Transmission: 200-4R
I'm looking to cross reference a part number for a fuel filter for an LG4. I want to make sure I get the right part, I've spent one too many days going back and forth between the part store lately. I'm looking for the part # for a stock fuel filter for the CC Carb on an LG4 (1986 Trans Am). A couple of the part numbers I have found are as follows:
WIX 33052
Fram CG3389
Purolator F10158
If anyone happens to have changed their fuel filter before and remembers the part number or has record of it somewhere I would appreciate it.
Old Aug 9, 2005 | 01:01 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Can't see any benefit of paying more for a "brand name" fuel filter when they will be the same as an AutoZone filter.
Part # FF104 at AutoZone is what I use on my car.
Old Aug 9, 2005 | 01:07 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Just look at www.fram.com
(On my TPI car the AC fuelfilter has part# : GF 481).
Old Aug 9, 2005 | 01:08 PM
ZMonte85's Avatar
The only difference I've found in price is about $0.50 to $2.00. Not that much of a difference, but it all does add up in the end right. Thanks for the info Nate.
Also, just to double check, the filter in the carb is the only filter on a CC Carb car correct? I've searched and this seems to be the general consensus.
Old Aug 9, 2005 | 01:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Those are the correct p/n's per partsamerica.com . I used the Fram.
There is also a filter sock inside the tank on the pickup. More of a strainer than a filter.
Old Aug 9, 2005 | 03:07 PM
ZMonte85's Avatar
Yeah, I knew about the sock inside the tank but I wasn't sure if there was an inline filter somewhere between the tank and pump. Thanks guys.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
