surface rust on cylinder walls
Old Oct 8, 2001 | 06:29 PM
sunbound's Avatar
Car: 1987 IROC-Z
ok, i pulled my heads off tonight, and the oil pan to see what damage the blown head gaskets did. (at least i assume that was the problem)
from what i can see... i have surface rust on the cylinder walls (as far down as the piston goes. when i pulled the oil pan, their was no oil/coolant sludge (oil shake).
now, the question i have is this... are they gonna need to go anything the the cylender walls because of the rust, or are they ok?
im gonna have them clean and check the mounting surfaces of the heads, block, pessure test the heads, and put the oil pan back on, with a new gasket. i could prolly put the oil pan gasket on myself, but i want to make sure its done right... i dont really think i could handle another big disapointment and having to pull the engine again.
thanx for the help you guys can give
jon
87 iroc, BW t-5, 350 tpi, no emmisions, centerforce dual friction.
"if you cant be good, be good at it"
Old Oct 9, 2001 | 06:32 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I would get some steel wool or 800 grit emery cloth and lightly knock it down. You might rotate the motor to get the piston down below the bad spot. But it should be ok.. Just lube the cylinder back and close it up to outside air.
Old Oct 9, 2001 | 06:47 AM
sunbound's Avatar
Car: 1987 IROC-Z
well, tomarrow im going to be taking the engine into she shop to get the deck checked to make sure its not warped or anything.... should i leave this up to the machineists, or do you think their gonna look at it and say "re-hone" and theirby raping me of more $ i could use toward other things for my car
jon
Old Oct 9, 2001 | 09:38 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Try cleaning the surface rust off with a rag and tranny fluid....you'll be amazed.
Old Oct 9, 2001 | 10:17 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
If you rehone the pistons would have to come out. not worth the trouble. Try what paul said.. also use some brake cleaner. If you can turn the motor upside down on an engine stand before trying to sand the stuff down. IT will just go down into the rings otherwise probably do more damage than it would just staying there.
If the cylinder is pitted then you will need to machine to clean it up.. otherwise i would just run it.
Old Oct 9, 2001 | 12:51 PM
sunbound's Avatar
Car: 1987 IROC-Z
ok, before i take it to the shop, ill try it... the motor is already upside down on the stand... pulled off the oilpan to make sure their was no oil shake in the bottom end... everything looked clean.
ill try the break cleaner and a rag tomarrow before i take it in, or ill take it in a day later.
i really hope this is the last time i gotta pull the engine in a long time... hopefully my car will hit the pavement before the snow does.... it would be the first time i drive it in about 9 months...
thanx guys, if their are any more ideas, keep em posted....
oh, afte i use the break cleaner, should i put oil on the walls after that? so they dont rust over again?
thanx
jon
Old Oct 9, 2001 | 01:02 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
<font face="Verdana, Arial" size="2">Originally posted by sunbound:
thanx
jon
</font>
I would. a real light coat of something and then a bag over it. Especially if you will be transporting it.
Old Oct 9, 2001 | 04:02 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Heck, if it's already on the stand, why not tear it down the rest of the way and hone it?
Originally I figured you were asking the question because the engine was in the car.
Old Oct 9, 2001 | 04:22 PM
sunbound's Avatar
Car: 1987 IROC-Z
because i cant afford the money to have the shop do that... and if i tear it all the way down, i might as well get the whole engine rebuilt.. if i do that, i might as well get high perf parts, and stroke it out... and i know my t5 aint gonna be happy with that... so then i gotta save up for a t-56 or some other 6-speed.
id rather get a 6-speed before i blow the 5.
if money wasnt a factor, i wouldnt have any problem with it.
thanx again for the help
jon
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
69GTOby
Apr 18, 2016 02:34 PM
GTAman
Sep 26, 2015 02:01 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
