Is An Aluminum Timing Cover Better?
Old Aug 11, 2005 | 01:15 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Is there an advantage to using an aluminum front timing cover over the standard stamped steel type?
Does it seal better? Do you need a different type of crank seal and pan gasket?
Anyone used one? What do you think?
Old Aug 11, 2005 | 01:25 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Is An Aluminum Timing Cover Better?
I think I would stick with steel. I tried chrome and they aren't worth sheit. Not sure about aluminum.
Old Aug 11, 2005 | 01:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Aluminum covers are cast instead of stamped, so they should seal better and deflect less if you're using a cam button.
Old Aug 11, 2005 | 01:40 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Not using a cam button, I don't want any leaks. So if I would have a better seal with the aluminum I will give it a try
Old Aug 11, 2005 | 01:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Steel covers seal just fine when they're installed correctly.
Old Aug 11, 2005 | 02:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
they look pretty.
thats the #1 reason.
they also dont deflect, if you're using a cam button... liked he said.
as long as they're made well, they shouldnt leak.
Old Aug 11, 2005 | 02:50 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Originally posted by MrDude_1
they look pretty.
I was gonna say that. Long as it's a good name brand part and hasn't been made in Tiawan or some place like that, you should be fine.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
NBrehm
Aug 25, 2015 11:49 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
