Have Few Questions about AL heads
Old Oct 10, 2001 | 08:22 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Do I use anything on the screw in studs? Antiseize?
The sparkplug recommended came with a washer do I use it or will it indent the aluminum?
Do I use antiseize on intake bolts and acc bolts?
Old Oct 10, 2001 | 09:32 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I use Permatex #2 for the studs (although I usually don't use studs)and intake bolts, antiseize where I feel it appropriate on the acc. bolts and if the head mnfg. recommended the spark plugs by number, yes use the washer.
"Question with boldness even the existence of a *** ; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old Oct 10, 2001 | 09:35 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Here's what I did on my alum heads:
antisieze on sparkies, exhaust/header bolts, and accessory bolts.
Left the washers on the sparkies.
Used hardened washers on the head bolts.
Used liquid teflon on the intake bolts and temp sensors.
Used felpro 1010 head gasket so it won't cut a ring into the surface of the head where the ring seals.
Dunno about the studs, mine were already installed.
I can't say that everything I did is right, it's just what my machinist recommended I use.
Old Oct 11, 2001 | 07:20 AM
ede's Avatar
ede
you need the washer on the plug because it's actually a gasket. use liquid teflon on the studs and anything else that goes to water. antiseize on everything else and use a torque wrench on every bolt that goes into the head.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
