Are the late model >87 SBC 305/350 internal or externally balanced?
Old Aug 17, 2005 | 11:38 AM
player 88's Avatar
Engine: 360 .060 over TPI
I remmber reading some where!! that the GEN 1 SBC with the single piece rear main seal in externally balanced? is this true or not? I am haveing to rebuild mine and wnat to upgrae the harmonic ballancer and possibly go to an aluminum flywheel.
thanks
steve
Old Aug 17, 2005 | 11:42 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The only factory Gen I SBCs that were externally balanced were the 400s. All others are internally balanced.
Old Aug 17, 2005 | 11:43 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i am wanting to say that it is internally, but i would wait on a second person to answer since i am not 100% sure
Old Aug 17, 2005 | 11:46 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Internally balanced. The flywheel does have an external counterweight on it due to the one piece rear seal, but the engine is internally balanced.
Old Aug 17, 2005 | 12:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The harmonic damper will need to be a neutrally-balanced part.
The flywheel will need to be a one-piece rear main seal part, which means it will not be neutrally balanced. But, that doesn't mean it is the same as a 400 flywheel.
This whole "internal vs. external balance" thing with one-piece rear main seal cranks is kind of silly. Technically, two-piece rear main seal cranks were "externally balanced", because the counterweight was outside of the crankcase - but, it was part of the crank. However, since one-piece rear main seal cranks cannot have the counterweight outside of the crankcase, the factory chose to put a weight on the flexplates/unbalance the flywheel to provide that function. As stated, the 400 engines were "externally balanced", because the damper and flexplate/flywheel were weighted to complete the balancing.
Old Aug 17, 2005 | 02:42 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
57, nailed it!
Hotrodboba400
Dec 10, 2019 07:07 PM
J.C. Denton
Sep 8, 2015 05:35 PM
roysatikas
Sep 7, 2015 08:08 PM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
