Diagnostics
Old Aug 17, 2005 | 04:09 PM
jsledge's Avatar
Car: 1991 firebird
Transmission: auto
Diagnostics
is there a way to turn the key and have the car self test by blinking back codes?
thanks
Old Aug 21, 2005 | 07:17 AM
Vader's Avatar
Welcome Aboard!
As you navigate the various pages on this site, you should see the icon on nearly every page. It is a very useful tool for finding archived information regarding specific problems, questions, or ideas. There is also a Tech section, which lists many common procedures and data relevant to our cars.
The specific procedure about which you are inquiring can be found by searching in various ways. This is the common method to retrieve stored error codes:
First, you'll need to acquire a GM OBD I ECM Diagnostic Trouble Code Retrieval Tool (commonly known as a paper clip to TGO members). Form this wire into a ‘U’ shape.
With the engine and ignition turned off, locate the ALDL connector under the dash, just to the right of the steering wheel in the driver's foot well area on some models, and on the left on others, depending on the make and year. There should be a small rectangular cover over the access hole in the lower dash trim, or at least was when the car was delivered.
Insert a tool as described above (paper clip) into the 'A' and 'B' terminals on the ALDL connector:
WITHOUT STARTING the engine, turn the ignition to the "RUN" position. Watch the Malfunction Indicator Lamp (MIL) - it will begin to flash. This is also commonly called the "Service Engine Soon" or "SES" lamp. The first code will flash three times, and will usually be a code '12'. This is encoded by one flash of the lamp, a brief pause, then two successive flashes of the lamp. Each code will repeat three times, so you should see a "Code 12" flash three times. Any other error codes will follow in numerical order, and each code should flash three times. After all codes have been displayed three times, the "Code 12" will again flash three times, then all other codes will follow as described earlier. This cycle will continue until the jumper is removed or the ignition is turned off.
After you have made a note of all error codes, turn off the ignition and remove the jumper immediately. If you forget to remove the jumper and attempt to start the engine with it in place, you could damage the ECM. For this reason you should remove it immediately.
Once you have a note of all error codes, check this file for the decoding:
GM Error Codes.pdf.
You'll need Adobe Acrobat Reader to open/print the file.
specialized
Jun 18, 2022 09:26 AM
GTAman
Mar 15, 2019 11:40 AM
mddaniel
Sep 8, 2015 05:16 PM
bowtie1983ss
Dec 4, 2001 12:18 AM
87ColdAirIroc-Z
Nov 9, 2001 04:31 PM
