When removing the airpump what size bolts do you put in the motor where the pump ?
Old Oct 11, 2001 | 01:40 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Where the pump bolted on to the motor near the fuel pump, what size are they and what length? thanks I have a 86 with a carb.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Oct 11, 2001 | 01:54 PM
iroc5speed's Avatar
I wouldn't think you would nee a bolt in place of it, though you could just take the original bolt that came out, thread it in to see how far it goes it, and buy another bolt of the threaded length, with the same size threads. Or you could just cut the bolt down to size with a hacksaw.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Oct 11, 2001 | 02:00 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I agree, just put the old bolts back in. That's what I did, but I have a serpentine setup so I don't know how your's is. As for the bolt size, 3/8 course thread.
Old Oct 11, 2001 | 02:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You absolutely DO need a bolt in the upper of the 2 holes. If you look in that hole, you will see the fuel pump drive rod. If you use a bolt that's too long, you will lock the drive rod in place, which could be disastrous if it happens to be all the way retratced at the time. Assembling a motor without a bolt there will produce one of the most aggravating mystery oil leaks you will ever face. Also, when you are changing out the fuel pump, you can use an extra-long bolt in that hole finger-tight, to hold the rod from sliding down and making it impossible to get the pump on right.
Use a short 3/8"-16 bolt in that top hole, about ¾" long, with some sealer on it. The original bolt is probably too long to go in and not hit the fule pump rod with the bracket gone. You don't need one in the bottom hole.
ICON Motorsports
Old Oct 14, 2001 | 01:20 AM
BLACK Z's Avatar
Car: 86 Z28
I used a 1/2 inch long bolt with some sealent, and a lock washer, that should do right?
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
kyleb24
Aug 15, 2015 08:24 AM
knight72
Aug 10, 2015 09:32 PM
3rdgenparts
Aug 8, 2015 07:09 PM
