Oil On Spark Plug Wire??
Old Oct 13, 2001 | 02:41 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I was in the middle of putting some wire looms on my wires today(because I have now burned 4 due to laying on headers, plus they were zipped tied together, talk about crossfire) and when I pulled off the #2 plug wire (which was routed to the back of the motor under the headers and up to the distributor) it had oil all over it. I know that I have had an oil leak for awhile, and was told it might be a rear main leak, however, due to this area on the wire does it appear that this leak might most likely be a valve cover gasket leak. And after I have finally learned to take care of your plug wires because well today I am going to buy my 4th set since I had the car a little over a year. I am putting on looms plus I have protective sleeves coming to handle up to 1400*.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 13, 2001 | 03:11 PM
JETHROIROC's Avatar
Most likely a valve cover leak, but other areas to check are the intake manifold and its bolts, and the distributor base.
Old Oct 14, 2001 | 12:40 AM
1BadAzzGT's Avatar
It also could be a bad seal... where is the oil specifically located at? Is it on the plug or the wire itself?
Founder, Tealnet.Com
'98 Mustang GT
My 98 GT
Mods: Vortech S trim, 42# inj, 5.4 Heads (ported/polished), custom ground cams, 99 intake, ATI 3 corer intercooler, Walbro 255 intank pump, Walbro 255 inline pump, Aeromotive adjustable fuel pressure regulator #13102, NO FMU!, Steeda Tri-Ax shifter, Steeda heavy duty LCA's, Steeda heavy duty UCA's, Steeda Chrome Moly subframes w/cross-brace, Steeda Cobra R hood (2 1/2" cowl), BBK 75mm TB, Pro M 80mm MAF, Eibach progressive springs, K&N Air, Cobra "R" rims, 31 spline Moser axles, SVO differential, Downs rear Girdle, FMS 3.73 gears, Cobra floor mats, Cobra leather shift ****, "A" pillar (Phantom White Gauges and custom gauge pod), Steeda race pedals, Mac offroad "H" pipe, hi-flo cats, and Borla XR1 catback.
Dyno #'s: 298.2rwhp/332.8rwtq (running rich 9:1 a/f)
Best ET to date: 13.42@104.91 (Temp F: 109 Humidity: 38 Barometer: 28.90) See the run on video!
Mods not installed: 3 core intercooler, ditching the FMU!
Old Oct 14, 2001 | 07:16 AM
Car: 99 Formula
Axle/Gears: 342
It was all over the wire, not the spark plug.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
