A/C delete pulley
Car: 1989 Camaro RS
Engine: 5.0 TBI
Transmission: 700-R4
Axle/Gears: 3.42 open....3.73 posi soon
A/C delete pulley
I was wondering where i could find a kit for getting rid of my a/c...it don't work and it sounds like a bearing is going on it or something. Plus i want to clean up my engine compartment a little bit and that big ol' compressor looks kinda ugly to me. Is it hard to get rid of the lines? Is there any advantages? Thanks alot.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Welcome aboard! IF you use the
function found at the upper right hand of the page you should be able to read up on the AC delete. You will find all the know how including part numbers to make your change over easier. Good luck!
function found at the upper right hand of the page you should be able to read up on the AC delete. You will find all the know how including part numbers to make your change over easier. Good luck! Thread
bigjay89gta
Oct 15, 2015 08:04 AM
