Need help with stalling problem...
Old Aug 22, 2005 | 06:54 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I'm helping my friend with a stalling problem on his 87 firebird. It has a 305 with a TBI setup from a 92 caprice.. The symptoms are as follows... most of the time it will drive fine.. every once in a while when driving real slow and coming to a slow stop it will just sputter and stall.. I thought it was a problem with the IAC valve so we put a new one in and the problem almost seems worse now.. is there a special procedure to installing one or do you simply screw it in and attach the plug? After it stalls it will sometimes take up to a minute to start again, it will then keep stalling. It only happens every once in a while, other times you can drive it all day and nothing.. im stumped.. any ideas?
*Notes: Fuel filter is new, good conical spray at the injectors.
Old Aug 22, 2005 | 08:16 PM
sellmanb's Avatar
Car: '86 Berlinetta
when has he tuned it up last?
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
