Brodix Track 1X Question
Old Aug 23, 2005 | 01:22 PM
meeklay812's Avatar
Car: '89 RS
Engine: 383 in progress
Transmission: TH 700-R4
I am looking at getting a set of brodix Track 1X aluminum heads. They have 222cc intake runners with 68cc combustion chambers. Anyone have any experience with these heads? Are they really that much better than the regular Track 1's? It says they require a T&D Economy or Jesel shaft system. Why is this? Any info on these heads would help. Thanks!
http://www.jegs.com/cgi-bin/ncommerc...44&prmenbr=361
Old Aug 23, 2005 | 03:00 PM
brutalform's Avatar
How large of an engine do you plan on building/using? The Track 1X are for 406 and larger engines.
Old Aug 23, 2005 | 03:03 PM
brutalform's Avatar
Sorry I just read your profile, and if using the same 383, go with the regular Track 1s.
Old Aug 24, 2005 | 01:31 AM
meeklay812's Avatar
Car: '89 RS
Alright well i guess that sums it up..... thanks!
Old Aug 24, 2005 | 10:09 AM
brutalform's Avatar
Yea, even if you decided to go with a solid roller on the Track1s, you can always buy a Moroso #67205, stud girdle, and you would come out cheaper than a Jesel.
Old Aug 24, 2005 | 06:41 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
The Track 1's are absolutely beautiful heads. Doing a build up now of a 6" rod 383 with them. I'll post dyno #'s after we get it done.
Old Aug 24, 2005 | 06:54 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
CYLINDER HEAD SPECIFICATIONS
INTAKE
PORT CHAMBER
VOLUME VALVE SIZES
INTAKE/
EXHAUST PLUG
ANGLE EXHAUST
PATTERN VALVE
CENTERLINE INTAKE
MANIFOLD
TRACK 1 221 cc 67 cc 2.080/1.600 Angle Standard Standard HV 1000 / HV 1002
SE 100 / SE 102
TRACK 1X 222 cc 68 cc 2.100/1.600 Angle Standard 40/60 HV 1000 Series
CYLINDER HEAD RECOMMENDATIONS
CUBIC INCH COMPRESSION CAMSHAFT RPM APPLICATION
TRACK 1 350 - 406 11.5 Minimum Flat Tappet / Roller 3500-7000 Oval Track / Drag Race / Pro Street
TRACK 1X 360 - 430 11.5 Minimum Flat Tappet / Roller 3500-7000 Oval Track / Bracket Race /
Pro Street
FLOW CHART cfm @ 28" H2O
VALVE SIZE 0.200 0.300 0.400 0.500 0.600 0.650 0.700
TRACK 1 2.080 INTAKE 124 179 228 264 276 278 279
1.600 EXHAUST 103 138 164 178 186 188 190
TRACK 1X 2.100 INTAKE 152 213 262 285 287 290 292
1.600 EXHAUST 113 152 173 185 192 194 195
I think the recommend the Jesel shafts because it will improve the valvetrane stability with the cams they recommend. I think it also has something to do with the 40/60 rating of the pushrod slots. Again, I think this has something to do with the geometry and stability of the Valvetrane.
Bubbajones_ya
Oct 25, 2015 08:01 PM
jaridjohn
Oct 5, 2015 07:01 AM
Numbah-1
Oct 2, 2015 08:27 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
