Spark Plug Wires?? 8mm or 8.8mm
Old Oct 15, 2001 | 05:08 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Would it really be worth it to buy Accel's 8.8mm 300+ Race wires over their regular superstock 8mm. What would be the advantages, I can get either for the same price, but that's all this is available locally, I'm off at college and I'm in the middle of nowhere.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 15, 2001 | 09:36 PM
GOLD85's Avatar
aceel wires are crap. i had 8.8s, they have to much resistance, i only use Moroso Blue max 8mm wires
when the green flag drops the bull$hit stops
pulled the 350 to make way for the 406 wich is in the machine shop. got a comp 282S bump stick with 1.6 rockers. looking at differnt heads right now.Perfomer RPM and holley 650 DP, headers and 3 inch exhust. 3000 stall converter and a built 700r4. shotin for mid 12s next summer
Old Oct 15, 2001 | 10:32 PM
Car: 99 Formula
Axle/Gears: 342
I have the Moroso on their now, but like a cheap idiot I never bought wire looms, and several are no good due to laying on the headers. But I now have looms and heat protective sleeving that will be here tomorrow. And what do you mean by too much resistance, sorry for a stupid question?
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Old Oct 15, 2001 | 10:35 PM
Tas's Avatar
Tas
I love MSD. Great quality. I have 8mm and 8.5mm in various vehicles.
-Tas
'89 Formula WS.6
Got Beach?
Old Oct 15, 2001 | 11:16 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I have Accel 8.8s in my car. I'm not a poster child for Accel or anything, but they are working just fine for me and were EXTREMELY affordable for me when I got them due to some classified friendships.... ...... hehe. And the ability of the wire to live and function in an extreme heat condition is much more indicative of it's quality than it's resistance @ 9 volts........
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 16, 2001 | 06:07 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I've never used the Accel 300+, but I can say that their cheaper wires suck bigtime. Had 3x the resistance of my old factory wires and two broke when I was taking them off. I've got Morosos on my truck. They're OK, but kinda a pain to get off the plugs. By far the best I've ever used is MSD. They are awesome and I will never buy anything else. Get MSD and you won't be disappointed.
Old Oct 16, 2001 | 03:16 PM
Matt87GTA's Avatar
I agree. Most people agree that MSD 8.5mm and the Moroso larger wires are very good. I was all set to buy the MSD 8.5mm wires, but I just couldn't justify how much more they were than what I was able to get the 8.8 Accel set for at that time. They are just plugwires and I am a full time student now!!
I've had a few bad experiences with those regular Accel wires. One of my friends brought over those 'Super Stock' or whatever wires for me to help him with a few years ago and we screwed around with them a bit and found them to dislike being removed - AT ALL. The plug boots just fell apart and their crimping job was less than stellar. Straight to the $hitcan they want..... We picked up a set of Moroso wires and they worked great and are still alive on his car. They were both cut-to-fit wire sets.... that is all I will work with as the 'custom' fit ones do fricken loops around the fender wells half the time and look like a$$. Other than looking a he11 of a lot nicer than the 'custom' fit ones, the cut-to-fit ones allow you to keep the length down on them, and subsequently, the resistance down........... But like I said, the resistance of the wire that is read on a DVOM that sends less than 9 volts through the wire can be very misleading.......
1987 GTA L98 MD8
My GTA
Old Oct 16, 2001 | 08:24 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I also agree accell wires are crap. I had good luck with MSD, but actually found Summit's generic spiral core wires (universal) to last (still on car, still getting cooked by headers for years)
They are cheaper and they come with a very half decent crimper to put the wire ends together.
Old Oct 17, 2001 | 02:18 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
I think the stock GM 8mm wires are perfectly serviceable
Old Oct 17, 2001 | 04:47 AM
ronterry's Avatar
Car: '94 Corvette
There's nothing weak about 150 ohms per foot, and thats exactly what my 300+'s are.
These wires might be over kill, unless your running a high energy ignition system.
Ron
Accel 300+ wires
Accel Cap & rotor
MSD HEI HO coil
MSD 6AL
Old Oct 17, 2001 | 05:58 PM
Dan87IROC-Z's Avatar
I would suggest the Accel 300+ race wires. They are the best set of wires I've ever had, they are 8.8mm and cost around $60 from Jegs.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Feb 25, 2004 | 08:42 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
stock size is 8mm? wow... i just pulled off my wires in exchange for some MSD SC wires(still got 4 to go) and those little skinnies were only 7mm. Dang, now i hope it can rev a lil higher seeing that the old ones weren't even stock size...
Brandon
Old Feb 25, 2004 | 10:08 PM
ronterry's Avatar
Car: '94 Corvette
OMG 'Tobias05' you resurrected an old post!!!
My updated list....
MSD 6AL
MSD 8.5 wires
MSD Blaster 2 Coil
MSD ProBillit Distributor
Ron
Old Feb 26, 2004 | 06:01 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
The question at the start of this thread is just fine, but why oh why do folk think one solution, or whatever they've got fits all!
Mark A Shields: The answer to your question is that the 300+ racewire is overkill for your engine. As is MSD etc. Accell Superstock Spiral is a reasonably priced upgrade from stock, so go for it.
Si. :lala:
ps. Will anyone that just wants to add a comment about I've got this/ thats crap etc etc etc go to the other lets bitch about accell threads and not clog up a perfectly reasonable question!
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
Bryan F
Aug 18, 2015 02:28 PM
