A.I.R and O2 question..
Old Oct 17, 2001 | 07:40 PM
breathment's Avatar
since the air thing is injecting air into the exhaust, then wouldn't that raise the oxygen content in the exhaust, therefore causing the O2 sensor to compensate, (or maybe the comp expects this) but if u disconnected the AIR system, then its not doing its job, and there is less O2. so wouldn't that screw things up a little? I mean i know the function of the AIR system is to help burn unburned fuel and stuff in the exhaust, but the O2 sensor is so close to the manifolds. Im sorry if this is a stupid question.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 17, 2001 | 07:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The diverter valve puts the air into the manifolds in open loop operation, and the cat in closed loop.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Oct 17, 2001 | 08:04 PM
breathment's Avatar
ahh, now it all makes sense
- David
quisterio
Oct 31, 2024 01:08 AM
