Distributor
Old Aug 27, 2005 | 10:32 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Distributor
I'm at the point now [all emmision gear gone] where my Edelbrock carb and manifold are fitted.
Now of course i realise, i need a distributor and coil with suitable vacumn advance. At the moment i'm still running the standard distributor.
Can someone recommend one that will go straight into a 305, with not too much wiring to change, and i'm not going into competition with it, so i dont want to spend stupid money.
I take it then you can unplug the ecu?
And where is the best place to wire the new distributor from.
Thanks in advance.
Old Aug 27, 2005 | 10:57 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
MSD is probably the most commonly used. Accel, Mallory, etc are also available. I have used a Mallory on my Caprice with no issues.
All non-cc distributors wire up the same, as long as you don't get one that is intended for an ignition box.
They just require a 12v+ hot source and the tach wire.
Old Aug 27, 2005 | 11:29 AM
R1UK's Avatar
Engine: 302
Axle/Gears: 3:73:1
Thanks, ive heard of Mallory and Accel but not MSD.
Had a browse of e bay and found this:
Mallory 262-454 CHEVY HEI DISTRIBUTOR 8548201C
Tach Drive: No
Gear Material: Iron
Computer Controlled: No
Cylinder Rotation: Right Hand
Helix Rotation: Standard
Housing Material: Billet Aluminum
Housing Finish: Natural
Cap Style: HEI/ Male
Coil Included
Advance Type: Vacuum and Mechanical
Trigger Style: Magnetic
Now does no tach drive mean no mechanical tach drive, or no connection for electric tachs?
Would be handy as it seems fairly in-expensive at $144.
Old Aug 27, 2005 | 11:41 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Tach drive would be a cable driven tachometer.
MSD is probably the most largely known aftermarket ignition company in existance. Mallory, like I said, worked fine for me, and was a cost-effective alternative to MSD. The part number you list looks exactly like the one I had. The 85 series, though, I guess, is a newer version, but I would expect it to be much of the same.
Old Aug 27, 2005 | 12:08 PM
R1UK's Avatar
Engine: 302
Axle/Gears: 3:73:1
Thanks for the fast replies, this has to be a quick learning curve for me.
Summer is almost at an end [if it started at all ] and i'm past wanting to work on my own cars during winter, that, and its booked in to be painted 14th of september, so if i can get it into a decent running mode before then, i'm a happy bunny.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
