Removing Smog Pump, What Size Torx?
Old Oct 20, 2001 | 12:09 AM
RS91's Avatar
I'm Trying to remove my smog pump, and would like to know what is the size of the Torx bolt???
RS 91 TBI. 5.0. Vin E..
Old Oct 20, 2001 | 03:45 AM
rezinn's Avatar
Im guessing 45, I think it is the same as the runner bolts on the tpi setup.
Old Oct 20, 2001 | 05:32 AM
crucial's Avatar
I think they're actually T-50. You can get by with a T-47 like I do sometimes but you will strip the bolts easier. Those bolts are definetly bigger then the runner bolts!! Maybe the same size as the intake bolts.
1991 Z28 6.0 TPI
360 4 bolt main block, TrickFlow 23 degree heads, CompCams CS270HR cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM SLP Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, 2500 stall, bullet proof 700R4, aluminum driveshaft...
Old Oct 20, 2001 | 05:51 AM
RS91's Avatar
Thanks, I will try these sizes..
italiano67
Dec 11, 2016 09:21 AM
toronto formula
Nov 10, 2015 06:17 AM
backtothe80s
Sep 5, 2015 12:39 AM
knight72
Aug 10, 2015 09:32 PM
3rdgenparts
Aug 8, 2015 07:09 PM
