belt size for AC/smog delete
I am in the middle of changing my water pump and I am remvoving the AC and smog pump if anyone knows the correct size/part number it would help me alot. Thanks to all those who reply.
88 Firebird Formula
350 T.P.I. (Stock unfortunately)
Ford finally had a good idea, they put heaters in tailgates/trunks.
88 Firebird Formula
Car: 84 TA
Engine: 305 L69
If your deleting your AC & smog pump you don't need belts, right?
Your PS & ALT belts should be seperate and not change.
84 Trans Am HO L69 WS6
5 Speed manual
Vortech Cherrybomb no cat
Removed A/C A.I.R. Hdflap
H/made cld air induction
K&N
Otherwise STD
5 Speed manual
K&N
Otherwise STD
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
in 86 or 87, fbodys went to one serpentene belt for everything. But, I used an AC delete idler pully (came on 1LEs) and took the internals of my airpump apart, so, i stiil used the same belt and routing.
Car: RS
Transmission: 4L60
danger you have v-belts and I'm pretty sure that IH8FORD, has a serpentine (sp). I'm not sure what belt you want, but I'm gonna do the samething.
I'm sure that someone knows, and if no one replies think that you could just measure it yourself and go to a napa dealor and they would 'hook you up'.
late model 91 rs, fully loaded, auto, t-tops, red leather, paint- gm red and yellow blend (light red), custom painted 16" Camaro rims
305 tbi flat base 14"x3" with K&N, hypertech chip, accel super stock plug wires, only use full synthetic oil and delco filter, 2 1/2" cat delete pipe, Edelbrock 3" cat-back
MTX sub and amp, Bose all around
vic_v8@yahoo.com
street kills: New v-6 stang, 96 v6 camaro, totally killed '86 SC Camaro (305), 91 z 28 with 305
15.854@87.57 (I think I could have it 15.5 with good tires and two more runs)
next month: rest of ultimate tbi
vic_v8@yahoo.com
