Where can i find head casting numbers?
Old Oct 23, 2001 | 09:05 PM
Hulk0202's Avatar
Old Oct 23, 2001 | 09:17 PM
Vader's Avatar
Hulk,
If you have a cast iron head, you'll have to have someone else look at the number, or use a couple of mirrors.
(Just a little iron-head humor - very little, I know...)
The head casting numbers are typically in the rocker area. You'll have to remove a rocker cover to find the number. You can see the cast numbers here, between the valve springs:
For all of those looking for case casting numbers, this is always a good place to start:
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 23, 2001 | 10:48 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
He may have meant 'where can i look up head casting #s', which would be www.nastyz28.com and www.mortec.com
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.7 @ 93.6
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Steve78LT
Feb 24, 2016 12:15 AM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
blackd-out z28
Aug 15, 2015 08:18 PM
armybyrd
Aug 10, 2015 09:23 PM
