windshield washer pump losing it's prime...
Old Oct 24, 2001 | 10:47 AM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
and therefore there's NO fluid coming out of the nozzles to clean the windshield (bloody dangerous).
everytime i bleed it and few minutes latter...no fluid again (gggrrrrrr)
there should be a check valve of some sord to prevent fluid from going back to the reservoir (=no return valve)
please help before i end up at the NUT-house.
fernando. :MAD:
third gen muscle power is the only thing that can match the power of flight...
Old Oct 24, 2001 | 02:14 PM
Danger's Avatar
Car: 84 TA
Engine: 305 L69
Hey dude I just fixed mine. It was doing same thing. I removed it, 3 bolts and nut to wiper arm (need to remove vent screen) and cleaned up the electrical conections with sandpaper and switch cleaner. Seemed it just had a bad earth. Now works great. Could be worth a try as its easy and no cost.
84 Trans Am HO L69 WS6
5 Speed manual
Vortech Cherrybomb no cat
Removed A/C A.I.R. Hdflap
H/made cld air induction
K&N
Otherwise STD
Currently painting
Old Oct 24, 2001 | 02:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Front Windshield Washer Pump Response Time
Number: 84-123
Section: 10(I)
Date: May, 1984
Subject: FRONT WINDSHIELD WASHER PUMP RESPONSE TIME
Model and Year: 1984 CAMARO
TO: ALL CHEVROLET DEALERS
Some customers may comment on some 1984 Camaros front windshield washer pump response time. A properly operating system will apply a full spray pattern of fluid to the windshield before the completion of the first complete wipe cycle (from park to full wipe, back to park).
This condition is attributable to the washer fluid draining back into the container and the washer pump having to be reprimed.
<img src=http://members.home.com/crussel/hose_routing.gif width=75%>
To correct this condition, the washer hose must be rerouted to provide an anti-drainback loop. This is accomplished by routing the washer hose under the accelerator cable, over and rearward of the brake booster, down to the side rail and forward to the solvent container (see illustration).
The washer hose should be shortened as required to eliminate the excessive length. The right and left hose assembly to the washer nozzles should be replaced with 5/32" (4.0 mm) inside diameter hose, and routed per illustration. (Start of production hose was 7/32" inside diameter.)
The hose routing change was implemented in January, 1984. The small diameter hoses were implemented in production in April, 1984.
[This message has been edited by Apeiron (edited October 24, 2001).]
Old Oct 24, 2001 | 03:53 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Apeiron bud, you rock man !!!
it was as simple as that, thankd to both of you guys.
fernando.
1992 Trans Am
May 10, 2023 07:19 PM
mustangman65_79
Apr 14, 2017 05:37 PM
lt1z350
Sep 29, 2015 01:50 PM
LittleFranks
Sep 17, 2015 12:22 PM
Randomtask2
Aug 26, 2015 03:34 PM
