Camshaft Choice Help
Car: 87 Z28
Transmission: 350 Turbo
I have a 89 RS with a 305 that just bit the dust. I am in the process of build a 350 (77 4-bolt main) here are the specs so far.
77 350 .40over
462 home ported heads shaved .010
edelbrock preformer intake
reconditioned stock rods
new cast crank
faltop pistons with four valve relifs
10:1
hooker heades
hooker cat back
stock y pipe
600 edelbrock carb
3.73 Gears
700r4 with stock converter
I plan to drive it to work during the week and race on the weekends. Does anyone have an suggestions on what cam would work best with this setup.
77 350 .40over
new cast crank
10:1
hooker heades
hooker cat back
stock y pipe
600 edelbrock carb
3.73 Gears
Transmission: 4L80E/4L80E
Re: Camshaft Choice Help
Originally posted by rustyZ28
P.S. I would like to keep the stock converter.
Loosen up on the converter, and you'll have much better options available to you.
gixxer92
May 18, 2017 11:20 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
