fuel pupm not comming on (long)
Old Oct 25, 2001 | 08:36 PM
86-firechickenT/A's Avatar
Okay, my car hasn’t been started in about 6 months since its been parked. I'm getting ready to have the engine rebuilt so I wanted to start it up and move it around. It cranks but wont start. I do not hear the fuel pump at all. I pushed in the Schrader valve on the fuel rail and there is no pressure in it. What all makes the fuel pump turn on? I know there is a fuse for it under the dash. That isn’t blown so I need to tack down why it isnt turning on. Where do I start? Thanks
Old Oct 25, 2001 | 09:43 PM
leirch's Avatar
Did you check the the fuel pump relay up by the drivers side under the hood? If you have a MAF system you will have two other relays also, if its the MAP setup you'll just have the one black relay, that should be the fuel pump relay. Check it to see if its working, you should be able to hear it move when its sposed to come on(when the ignition is turned on initially).
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
Kaweh
Aug 9, 2015 02:54 PM
