Electrical Qs
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Electrical Qs
Hey guys,
Im right at the end of my build and Im cranking
the engine to get the oil up where it needs to be.
valve covers, plenum, runners, EGR equipment, &
distributor cap are off the engine
as of now, oil is prevelant uptop on all the rockers,
lifters are brand new and are doing thier job ..
rockers adjusted and everything looks smooth
but the problem is the starter, when I crank the motor
.. I just trip the solenoid out with a bolt to crank it.
it doesnt make a sound when I turn the key inside
the car. The starter is wired correctly and power to
the starter is obviously there ..
is this because the top end is not assembled and
grounds to the back of the heads are not connected??
I figured the grounds to the heads didnt matter
when cranking the motor ..
I have the fuel pump and injector fuse pulled so
no fuel can get uptop..
most but not all sensors are connected, and
power is inside the car, the door buzzer works
and headlights move up, but they fail to return to
the closed position.. (relay or ground wire??)
anyway,
I want to be able to crank for oil to travel without
tripping the solenoid with a bolt everytime
(the bolt gets really hot!!!)
I figured most problems will go away when
everything is assembled ..but the starter should
actuate without a problem ..
whats going on here ..??
anyway,
TMZIrocZ350
Oct 7, 2015 12:09 PM
