removing side gfx
Old Oct 28, 2001 | 04:51 PM
rezinn's Avatar
removing side gfx
How do you take the gfx under the door off on an iroc? I got all of the screws out from inside under the door and the ones underneath the car, but it seems like there are still a couple bolts on each side. Do you need to get them from inside the car, by taking off some panels?
Old Oct 28, 2001 | 05:45 PM
Project86Iroc's Avatar
There are two speed nuts(11mm) That can only be accessed by removing the rear lower trim panel(on 88 and prior cars, where the belt strap comes out of) To do this, there is a phillips head screw back by the rear seat, and then your lower rocker cover. pull these, and youll see a rubber cover glued on, pull that, and the nuts are there. Youll need small, girlish hands, or a wobble extension to get these, but for gods sake, try not to get your hand stuck. In the front, there are two phillips screw beneath the Z28 emblem. Carefully pry at each side until the emblem comes out
Mike
I would love to be there when those Muslim Bastards hit the Pearly Gates and realize they were wrong...
Old Oct 28, 2001 | 07:49 PM
rezinn's Avatar
Thanks a lot Mike, much appreciated.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
LittleFranks
Aug 20, 2015 03:55 PM
Street Lethal
Aug 14, 2015 08:25 PM
3rdgenparts
Aug 8, 2015 07:09 PM
