brackets
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
brackets
I would like to change the stock brackets to aftermarket,
I have a 305 TBI with Serpentine belt...if someone can tell me who's brackets I can use would be greatly appreciated....I would also like to see some pic's PLEASE
IF i CAN COME UP WITH BRACKETS THAT WILL WORK I WILL GLADLY SELL THESE
Car: 89 iroc
i wsa talking about the a/c bracket, and alternator barcket...thought by serpentine setup would tell ya my mistake
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I am not aware of anything that is an easy switch.
You can get individual brackets from March, for V-belt setups, you would have to convert all your accesories, and water-pump, to use the v-belts, plus get all the brackets.
Or you could order a FULL kit from March or a couple other manufactures, that included all the accessories, and bracketry, but that gets into the $2k range, sometimes more.
What is wrong with your brackets? they are alum. So if you are going for looks, I suppose you could polish them.
Car: 89 iroc
yea that looks like the best plan...I found a place here in michgan where tou can use their machines to clean and glass bead everything for 12.50 an hour....for anyone in west michigan the place is called
consolidated stripping and derusting
http://www.consolidatedstripping.com/pages/1/index.htm
