compression
Old Sep 17, 2005 | 04:08 PM
Formula400's Avatar
Car: 87 firebird formula
Engine: 400 sbc
compression
what's the compression ratio on a 1975 400 sbc (882 heads)
does the cam change anything? (xe274h)
and how much would 72cc heads change it.. or 64 cc (more common)?
thanks
Old Sep 17, 2005 | 07:58 PM
Damon's Avatar
Pretty low. I recall it being spec'ed around 8.2:1 from the factory. 72cc heads won't make much difference. 64cc will raise it close to 9:1.
The cam won't change the mechanical compression ratio but it will lower the "dynamic" compression ratio. The bigger the cam the lower the cylinder pressure. At 8.2:1 the fairly large XE274 will be pretty doggy below 3000-3500 RPMs, even in a 400.
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
