What Brand Roller Rockers?
Old Sep 17, 2005 | 08:56 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I could use some help from the roller cam crowd,here.
I'm running Pro-Topline 220cc heads with 1.55 dia. roller springs.Up until now,I've been running an older set of Erson rockers.They have put their time in,I've had them on a TON of smallblocks.
But when I went roller,they interfered with the large springs,so I had to grind them down,which I'm told is common.
I've wasted several pushrods along the way,it would look like I had plenty of clearence,but after it would bend a pushrod,I'd find a boogered spot where the retainer had bound up the rocker.I'd grind a bit more,until I stopped having trouble.
Today,my fears were realized,a rocker popped.Not at the strip,not cruising the local hangout,not ripping down a back highway,no.That would have been too simple.
It had to happen on the chassis dyno shootout at the Street Machine Nationals.
Needless to say,I'm out of the running,but now I'm looking to others with this question,what brand of rockers are you using with your roller springs?I'm not "for" or "against" any particular brand,I just want to know before I lay down a bunch of cash what will clear and what won't.
Anyone?I'm all ears!
Old Sep 18, 2005 | 07:20 AM
ede's Avatar
ede
comp steel rockers don't fail because of fatigue like aluminum and are often lighter
Old Sep 18, 2005 | 07:27 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Shell out the cash for some gold crane roller rockers! I havent herd complaints about them yet. Thats what I want in my next engine.
Old Sep 18, 2005 | 10:20 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Comp Pro Magnum rockers. No modifications required. The steel design puts less weight and mass on the end so there's more room for larger springs.
The next step up from these is some shaft mounted rockers like Jessel which are very expensive.
Old Sep 18, 2005 | 10:45 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Another vote for the quality and design of the Comp Pro Mags. Between the body design and a good 7/16" stud, they're pretty beefy.
Old Sep 18, 2005 | 10:51 AM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
comp cams pro magnums
Old Nov 21, 2005 | 10:37 PM
Irockz's Avatar
Draggin' this up from the dead to share what I've learned.
First,there are 2 styles of Crane Gold rockers.1 is a wide body,which will clear roller springs with very mild clearancing.The narrow type,however,is more for near stock applications,and will only work with lesser spring ODs.
2nd,Comp Pro Magnum rockers leave a bit to be desired in tight clearance situations,I bought a set,and they come nowhere near working for my application.(got a real nice set for sale in the classifieds section).There is a notch above the Pro Magnums,Hi-Tech Stainless,by Comp Cams.They will clear with no modification,at least in my application.So,hopefully we all learn from my mistakes,and with a little luck,someone will own my nice set of Pro Magnums that can use them,anyone got a set of Stainless Comps for sale?
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
