Do third gen's have "keyway" or "press-fit" style Saginaw Power steering pump?
Old Oct 30, 2001 | 08:31 PM
383TAGTA's Avatar
Car: 1987 GTA originally 350TPI 3.27posi
Engine: 383 C.I.D.
Converting my 87 GTA from V-belts to Serpentine using March Performance Pulleys. I know I could go to the junkyard but I want the Billet Aluminum stuff to increase the aesthetics of the engine compartment.
Old Oct 30, 2001 | 08:34 PM
Vader's Avatar
GTA,
My '86 has a plain shaft - no key, no knurl, no spline. Just press it off and on. I'm almost certain the '91 with the poly 'V' belt that I had apart included the same sheave/shaft arrangement, so I would guess that the '87 would be the same.
One note about the aluminum sheaves - they look pretty but wear out faster. If you don't drive daily, it should be fine.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 30, 2001 | 08:52 PM
383TAGTA's Avatar
Engine: 383 C.I.D.
I'm planning to drive it a whole lot and not just have it parked in the driveway. I just don't want to look around for too many miscellaneous parts and brackets. The thing is my GTA does not have A/C, or A.I.R. pump. I bought the 1LE A/c delete conversion with different Power steering and and waterpump but need the other stuff. I know I'm going to go nuts trying to make this happen. Maybe someone with the Camaro Parts and ilustration Catalog can't tell me what part number would I need as far as brackets and bolts to convert from 87 to an 88 up serpentine setup without turning the A/C compressor or Smog pump. Please help.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
