Stalling in Reverse
Old Sep 20, 2005 | 09:46 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
Transmission: 700-r4
Stalling in Reverse
Ok...well ive noticed it a couple time lately doesnt happen all the time just when idling back in reverse car will completly shut off no stumbling which is making me think ignition related.
Recently Replaced:
MSD 8.5 mm superconductors
Accel High Performance Dist Cap
AC Delco Plugs
Fuel Filter
Fuel Pump
Timing was advanced just a lillte bit
Any suggestions???
Also I have a surging problem with the defrost on maybe vaccum leak??
Old Sep 24, 2005 | 08:11 PM
Vader's Avatar
Check the primary ignition wiring, ground straps, and plugged connections at the distributor, ESC, coil, and fusible links. The opposite torque-up of the engine in its mounts caused by moving in reverse could be straining a weak connection.
Hotrodboba400
Dec 10, 2019 07:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
