drain coolant
Old Sep 23, 2005 | 12:34 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
drain coolant
ok i am changing my heater core but do i have to flush or drain my coolant. do you have to in order to change the heater core. the coolant in my car is about 3 weeks old. also how do i drain the coolant the right way no flush but drain.
Old Sep 23, 2005 | 02:39 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
If your changing the core because its collapsed and is full of rust and silt, yes i would flush it and refill.
If it just burst, and theres little or no rubbish floating in it, then probably not.
Theres usually a drain tap on the bottom of the radiator, facing the engine block.
Anti-freeze isnt that expensive, so dont go the cheap way just to save a few pennies.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
