trouble getting the knock sensor in
Old Sep 25, 2005 | 12:42 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
The block is a '91 L98 from a 'Vette so it did at one point have a knock sensor in it but I have had the engine carbed since I've owned it. Now I'm converting it to efi but I can't get the knock sensor in more than like two threads because it's hitting the oil pan lip. From what I see there's only one spot per side of the block to put it in. I'm going to use a close nipple and female/female adapter to set it out from the block about an inch, will this affect its readings?
Old Sep 26, 2005 | 11:07 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I wonder if you're using the correct hole? Been awhile since I looked, but seem the recall it's no where near that close to the pan.
I know that doesn't help with your specific question.
Old Sep 27, 2005 | 09:11 AM
Car: '87 Camaro LT
Engine: 355 L98
It was the only hole I could find tapped for NPT. I got a close nipple and female coupler and that worked fine.
L98GTA87
Oct 19, 2015 10:43 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
