305 bore question
Old Sep 28, 2005 | 01:58 PM
liteumup387's Avatar
Car: 1982
Transmission: 350
305 bore question
i have a quick question. i have a chevy 305 out of a 92 camaro 2 bolt main. my question is can i have that engine drilled out to be a 4 bolt main and can a 305 be bored out to a 383?
Old Sep 28, 2005 | 02:02 PM
Damon's Avatar
4-bolt conversion, yes.
383, no. The much smaller bore of the 305 (3.736") will only give you about 332ci if used with the same crank you would put in a 350 to make it into a 383 (3.75" stroke). You can't bore out a 305 block anywhere near enough to get to the 4.030" bore you'd need to make a 383.
Old Sep 28, 2005 | 06:49 PM
Car: 1982
Transmission: 350
ok i didnt think so but id figure id ask thanks
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
