Need advice on radiator selection.
Old Nov 4, 2001 | 04:17 PM
poncho9789's Avatar
I am shopping for a new radiator for my TA. I found a aluminum/plastic 2 core radiator for $116. And I found a copper 3 core for $130. Would the aluminum radiator cool better than the copper or would it be backwards? Both have lifetime warrentys.
Old Nov 4, 2001 | 04:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They cool about the same. However, the copper/brass one puts a good 10 extra pounds on the nose of the car.
ICON Motorsports
Old Nov 4, 2001 | 11:12 PM
poncho9789's Avatar
I have an 89 GTA what did the car come with from the factory aluminum or copper and how many rows did it have?
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit,2800 converter, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,holly afpr,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil,150 shot NO2. This car is currently under rebuild and restoration.
Old Nov 5, 2001 | 12:32 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
The factory radiator is an aluminum one with plastic side tanks. I believe it is a 2 core but I am not sure.. (brain fart)... Someone will know for sure
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 5, 2001 | 08:02 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Go to Napa and get a Modine radiator. It will cost you about $100. It is Aluminum. It is considered a one row radiator, which is the equivelent of a three core. I just put one in my car and I am very happy with it. It cools just as good as the old one, if not better. Don't forget a new cap.
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs; Removed Smog Pump and all other Smog related parts.
Old Nov 5, 2001 | 11:59 PM
poncho9789's Avatar
Thanks guys I just got the Modine alu radiator, new cap, Waterpump, and thermastat.
sheachopper
Jul 31, 2019 11:27 AM
jaridjohn
Oct 5, 2015 07:01 AM
