speedo cable
Old Nov 6, 2001 | 02:32 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
speedo cable
stupid question, but i lost my manual how do you change the speedo cable :-D (car is 82 camaro z28 w/ 3 speed)
Old Nov 6, 2001 | 08:42 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
Basically the cable screws into the tailshaft housing of the tranny and into the back of the speedo. I'm not sure exactly what all it will take to get it out and through the firewall. There should be a grommet on the firewall that you can temporarily remove to get the old cable out and the new one in. It should be fairly straight forward other than that. You just might have to snip a couple of wire ties holding the cable out of the way of wiring harnesses. I wish I could tell you more in detail but I've never done it on a thrid gen before. Hope this helps some.
Jason Lodder; 86 IROC-Z, 305 TPI/700R4, Flowmaster Exhaust, Hypertech Thermomaster Chip, K&Ns, Throttle body airfoil.
Old Nov 7, 2001 | 08:19 AM
WideOpenVTwin's Avatar
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
<font face="Verdana, Arial" size="2">Originally posted by J's86ROC:
</font>
You hit it right on the nose. Instead of wire ties, there are two clamps that need to be unbolted. You can detatch the cable from the back of the speedo from under the dash. Get a flashlight and look up at it, you will see a metal peice retaining the cable. Just push it towards the speedo with a screwdriver (or ur hands) and pull the cable.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
