need help
Old Oct 2, 2005 | 10:16 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
need help
car idles high(1500rpm), idle surges between 700 and 1000rpm and got a code 45. these symptoms are not present all the time. a lot of times it idles fine.
Old Oct 2, 2005 | 10:49 PM
Vader's Avatar
Your oxygen sensor may be toast. Age, wear, fuel contamination, contamination from coolant of silicone sealant outgassing, or physical damage can kill a sensor.
Old Oct 2, 2005 | 10:50 PM
87zjeff's Avatar
just replaced it this morning. was doing this before the 02 sensor but never had a code before
