bad fuel pump test
Old Nov 7, 2001 | 01:06 PM
87ColdAirIroc-Z's Avatar
bad fuel pump test
HOw can i test to see if my fuel pump is bad
It does not activate with ignition, or when 12 v is jumped to terminal g of the diagnostic connector. Obviously fuel pressure is 0 psi. I replaced the relay already. that did not help.
87 Iroc-Z 350 TPI
Dynomax exhaust
modified MAF & filter box
modified ARAP chip
3-10" JL subs
Eclipse components
[This message has been edited by 87ColdAirIroc-Z (edited November 07, 2001).]
Old Nov 7, 2001 | 01:26 PM
Vader's Avatar
87,
Have you checked the voltage directly at the tank connections? How about the ground connection?
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Nov 9, 2001 | 10:23 AM
Thanks I got it working now. I thoughtI had checked the fuses but the fuel pump fuse is located in the engine compartment and it was blown.
thanks
jake
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
