Weird?
Old Oct 6, 2005 | 05:10 PM
82knightrider's Avatar
Transmission: TH200C....700R4
Weird?
I went to get gas today and gave the cashier 60$ .I got 91 octane and started filling up.I thought it would start to top off around 15 gallons or so.But it kept flowing,took a 60$ worth of gas,18.993 gallons to be exact(3.15$ /g)
Im stumped,I thought our tanks only held 16 gallons or so.So why did mine take almost 19 gallons I was bone dry empty when I rolled in but still.
It was for my White 83 CFI BTW.
Ive never had this happen with my blue car ever
So my question is....is this normal? Do I have a leak somewhere and its escaping through there?I look under the car all the time and see no gas.So if there was a leak does the gas evaporate into thin air as soon as it makes contact with air Maybe that will explain why I never see gas on the floor.
Or maybe the previous owner installed a larger gas tank
Old Oct 6, 2005 | 05:21 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Maybe that pump is rigged . Allthough I no nothing about the CFI camaro . I thought the tanks are the same too . Go back and fill up a gallon type can , and if it is off report them we,are paying to much get rippet off .
Old Oct 7, 2005 | 01:10 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Yeah sure sounds like a scam, but most gas stations are smart enough to make it a little less obvious. Your not gonna miss seeing or smelling 3 gallons of gas on the ground.
Old Oct 7, 2005 | 01:51 AM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
Your car definately did not take that much gas. Stock, your car would have been pouring gas all over the ground. At least 9-10 dollars worth. At 3 dollars a gallon, for the past few weeks, on empty, my car takes 40-45 dollars to fill up(when it was 25 dollars a couple years ago! ) You've been ripped off, intentially or otherwise.
Old Oct 9, 2005 | 03:55 AM
BackInBlack86's Avatar
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
you've been had... no way that tank held that much, especially if you drove it to the pump.
Old Oct 9, 2005 | 07:03 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
You didnt leave it running while you filled it up did you?
Old Oct 9, 2005 | 01:31 PM
no,it wasnt running....
F-body-fan
May 4, 2026 09:42 AM
db057
Jan 10, 2020 08:55 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
BWilcox
Sep 20, 2015 12:19 PM
