Fuel pressure test fitting
Old Oct 7, 2005 | 12:46 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
does anybody know what size fitting they use for the fuel pressure test port on late model gm engines I need to know so I can get adapters (if i need) to hook my car up to a injector cleaning system andy help is appreciated
Old Oct 9, 2005 | 01:40 PM
Vader's Avatar
What year? What engine/fuel system? The fittings vary depending on system type. TPI is different than CPFI. LT1 is also different.
Old Oct 9, 2005 | 04:17 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
I remember reading that the TPI one is -4an.
Old Oct 9, 2005 | 05:33 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
TPI and LT1 are the same, as are most late model GM's. Even the LS1. Not sure on the size but it's the same as a valve stem on a tire. -4 sounds close.
Old Oct 9, 2005 | 10:55 PM
Vader's Avatar
Yes, the TPI and LT1/4 are the same. TBI is different. Vortec/CPFI is different yet. That's why I have three different pressure gauges.
Old Oct 10, 2005 | 02:13 PM
Car: 89 Formula
Ok so its 1/8 npt thanks for info
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
