Multi directional tilt steering wheel = scary
Old Oct 11, 2005 | 04:14 PM
Supermann's Avatar
Car: '86 Camaro, '85 Z28, '92 Firebird
Engine: LB8 2.8, LG4 5.0, LO3 5.0
Transmission: TH-700R4, T-5, TH-700R4
Axle/Gears: 3.42s, 3.23s, 2.73s
Has anyone ever had the steering wheel like pop out a half and inch and start to tilt a little in every direction? lol I was driving and as soon as I pulled out of my parking lot I realized the wheel was pivoting a little in every direction. Anyone know what I should do to fix it?
Old Oct 11, 2005 | 04:34 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
get the tilt pivot pin removal tool ,the locking plate removal tool, steering wheel puller. misc screw drivers and torx drivers, I think inverted torx sockets and have at it. there are 4 inverted torx bolts that come loose aver time (seems common with cars where people use the tilt often)
I am sure there is a write up around here if you really want the details
or replace the whole colum assembly with a salvage yard one
Old Oct 11, 2005 | 04:42 PM
llvll4l2c91350's Avatar
sounds like the tilt bolts inside the column are loose. common GM problem.
its a lil bit of a PITA to get to them, but not too bad.
Old Oct 11, 2005 | 04:52 PM
Supermann's Avatar
think this might be a good time to just go ahead and install an aftermarket wheel? I was considering getting one, I was just putting it off.
Old Oct 11, 2005 | 06:11 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
May as well replace the wheel while its all apart if you want an aftermarket one.
Old Oct 11, 2005 | 07:19 PM
Supermann's Avatar
ok, well, is it ok to be riding around with the wheel loose, because I would have to take it home in order to fix it, and I want to make sure this thing isn't going to come off in the middle of me driving down the road lol
Old Oct 11, 2005 | 07:29 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
That would be cool to have a nascar style disconnecting steering wheel, just wouldnt be fun to find that out at 80mph lol
Old Oct 11, 2005 | 07:50 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
occasionally (only occasionaly) when i get out of my car now, i use the steering wheel for support usually and sometimes it makes a horrible ratcheting noise and comes down
ive never been in there to see the parts everyone is always talking about, but would the loose bolts cause that also? cos otherwise its tight, maybe the lever is messed up..
Old Oct 11, 2005 | 08:10 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
dr1 - i would say the tilt mechanism that locks it has worn out causing it to skip down, but just like you havent had a thirdgen column apart yet so im not sure of all the componentry.
Old Oct 11, 2005 | 08:14 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
my steering wheel doesnt move up or to the sides, but if i push straight forward on the top half of it, it will tilt forward a bit, inch or two. the tilt works fine, can put the wheel whereever i want it, but then itll tilt up from that position. doesnt stay, goes back to normal, so i dont really worry about it, but it could get ugly if i ever had to corner while braking hard.
Old Oct 11, 2005 | 09:43 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Mine did that, the fix is take the wheel, lockplate, ignition tumbler, etc. out and take a 3/16s socket on a 1/4 drive with a fairly long extension and tighten the tilt bowl screws up. You can only get to 3 of the 4! The 4th will eventually end up on the floor board.
Old Oct 11, 2005 | 10:11 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
I work at a pontiac dealer so Ive done one or two of these in my time I always tear the column down to get all four bolts, remove them one at a time and put loctite on them and run them back in tightly and then theres no more problems with them backing out.
Old Oct 11, 2005 | 10:14 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Mine did that and I found out the pivot pin on the left side fell out onto the floor! I popped it back in and smacked it in with a 12" ratchet extension and a hammer, but it still falls out every few months. This is on a 1991 steering column, so I don't know if it would apply to you.
Old Oct 12, 2005 | 08:59 AM
Engine: ls1, LB9
next time you put it back in, take a small punch and hit the aluminum just to the side of it. so you push a very small amout of aluminum over it. that is all it takes to keep it in there.
Vintageracer
Jan 10, 2020 05:33 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
