Fuel Pressure Question
Old Nov 13, 2001 | 11:00 AM
MSD tech's Avatar
I have a question about what fuel pressure the factory pump should be able to sustain. I built an adjustable regulator for my 92, I set the pressure at 50 and after 10-15 miles the pump started screaming and the car shut off. Not having any tools, I limped the car home and reajusted it back to stock and all is well for now. I am assuming the pump is just old and not able to keep up. Secondly what aftermarket in tank fuel pumps are you guys using? Are any of them more reliable then the next? If I am changing it I might as well upgrade it. Thanks for any feed back you might offer. I posted this in two forums, I was not sure which to post it in. Sorry.
Joe
Old Nov 13, 2001 | 06:53 PM
ede's Avatar
ede
for stock type applications i like the stock ac pump if you're after preformance walboro (sp??) makes a good pump.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Nov 14, 2001 | 11:20 AM
MSD tech's Avatar
Thanks, that's what I am going to do. For the $$ the 255 is well worth it.
Joe
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
