What Will It Do?
Old Oct 14, 2005 | 07:33 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What Will It Do?
I'm building up my 350 alot in the spring, and I've started collecting the parts already. I have a few, but not all of these.
- Fresh '79 Z28 shortblock (rebuilt to original specs about 15k ago, stock type dished pistons, etc)
- AFR 195cc (68cc chamber) aluminum heads
- XE274 cam from Comp Cams
- Edelbrock RPM Air Gap intake manifold
- Holley 4150 double pumper (650cfm)
- Vacuum advance HEI w/ hotter coil, weight/spring kit (I'll adjust this as needed when its running)
Right now the 350 is almost completely stock, except for a 14x3 open air cleaner and K&N element, a set of Hedman shorty headers, and a 3" Hooker exhaust with a 3" cutout.
...Now, I know someone who recently built a 400sbc with basically the same top end as what I'm planning (although he used a 750 Demon DP and MSD ignition) and a little bigger cam. He used the same intake and heads, he also has the same rear end gears that I use (3.73)
I've seen his car consistently run VERY low 12s and hit high 11's a couple times. A chassis dyno says he made around 365 rwhp.
So now I'm curious... what would my planned setup, which is pretty similar to whats on his 400, do on a 350? A few guys have said I could hit 12s if I can shift and get tires that stick (I'm running a 4spd, not auto). I'm hoping for mid 13s
What do you guys think?
Old Oct 14, 2005 | 08:53 PM
Air_Adam's Avatar
Also, I need to know -
The AFR heads are available in straight and angle plug versions.
Will my headers (Hedman 68470 shorties) work with angle plug heads?
Old Oct 14, 2005 | 09:23 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Like I said before Adam, I think it is any easy 12s combo. Its pretty much exactly what I started building 2 years ago - the only difference was that I used 1.6 roller rockers and hooker 2210s. I guess you'll have lower compression though...
So far my 3600 lb car has went 114.7mph (118 corrected) so far and there is a bit more in it for sure. I think that 105ish reasonable for your planned setup.
Trevor
Old Oct 14, 2005 | 10:54 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
It could probably take a bigger carb, probably 750. The biggest issue I see is the compression. Depending upon how dished they are, of course. Also, deck height, etc.
You plan on keeping the 5 speed I presume?
Old Oct 15, 2005 | 01:17 PM
Air_Adam's Avatar
I'm swapping to a 4-spd. I can't remember the dish of the pistons, but the CR ended up around 9.7:1
Trevor - Your TA weighs 3600lbs?
Old Oct 15, 2005 | 01:20 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Well then if you go from 76cc to 68cc chamber heads your should be close to 10.5:1 compression but I can't see you having that much compression on a dished piston big chamber head. Was your deck zero-decked?
The car weighs 3600 with me and half a tank of fuel.
Old Oct 15, 2005 | 03:14 PM
Air_Adam's Avatar
I should have worded that better.... my CR right now is not 9.7:1... Thats what it calculated out to be with 68cc chambers and a stock head gasket. Right now, with the stock smog heads, its 8.X:1 compression.
Does anyone know if my headers (hedman 68470 shorty) will work with angle plug heads??
Old Oct 15, 2005 | 03:40 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Should be mid 12s with ease assuming you have suspension mods and traction.
I have mildly ported LT1 heads with an LT1 intake and that same cam and I plan to run very low 12s or high 11s with traction. That's once I get used to driving stick, or if I get a nice big stall on a rebuilt auto. I'm using SLP 1 3/4" headers and have a 10.5:1 compression. My car is pretty light though too. I'm not sure what it is exactly, but by race season next year, it'll be some 325lbs+ under stock.
EDIT: I don't know why I was thinking I have an XE274 cam...I went slightly smaller and took the XE268 grind instead. Either way, I'm still looking for low 12s/high 11s with this cam.
Old Oct 15, 2005 | 04:44 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Your compression ratio is going to be lower than you think with dished pistons and 68cc heads on a 350.
Is your block decked? A factory piston does not come all the way to the top @ TDC. Some rebuild pistons actually sit lower than the factory piston @TDC.
you are not stuck with a 68cc head from AFR.
Head milling and chamber cc check is a extra cost option that you can order for your heads if you buy them factory direct or from a supplier that does its own machineing. ( machine shop) Milling the head will reduce the valve to piston clearance and effect the push rod lenght.
Old Oct 15, 2005 | 10:13 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
just my opinion,but I really think your looking at high 12s once you get your combo sorted out and in tune.
ever thought about a 125 hit of juice?I had great success with it in a cast piston 355 a few years ago,I just followed the tuning instructions to the T,and never hurt it a bit.
One last thing,I say stay with the 650,it's plenty of carb.Proform main bodies are cash very well spent,though.
Old Oct 16, 2005 | 01:34 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Blow up
na, high 12's perhaps Low 13's?
