oil change = idle change?
Old Oct 15, 2005 | 01:43 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
I just finushed changing the oil in my 350. In the ten minutes it took me, the idle dropped +- 200 RPM. I did change from 30 weight to 40 weight, but is that enough parasitic drag to pull my idle down? what happened? oil pressure is up a little, but not more than 5psi.
Old Oct 15, 2005 | 03:07 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Yes oil viscosity will definately affect your engine. All that heavier oil takes more power to run the pump and push it through the oil galleys. And you also have that hevier oil flinging around on your cam and crank.
Old Oct 15, 2005 | 04:27 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Ehh I've run 10w-30 to 20w-50 before and my motor has never lowered in idle. Its not that big of a differance. I'd start to look at some other stuff.
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
I would say it should make enough of a difference also.
noticed the same thing on my mazda
Old Oct 15, 2005 | 07:59 PM
Car: '85 TA
well, im having carb tuning and distributor issues, so maybe the extra viscosity is just enough to put me over the edge.
Old Oct 15, 2005 | 08:56 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
strange but my volvo 940 turbo does the same thing come to think of it.
Old Oct 16, 2005 | 01:05 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I changed from 20W-50 to 10W-30 when the weather started to cool down, and I noticed the idle raised about 100rpm or so, hot or cold.
Old Oct 16, 2005 | 08:25 PM
Car: '85 TA
sounds like its a pretty common thing, so i wont worry about it too much.
eightsixseven
Dec 16, 2024 01:50 PM
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
