more questions! heads
Old Oct 19, 2005 | 01:19 AM
Shribe's Avatar
Car: 1988 IROC
Transmission: 700 R4
Axle/Gears: 2.77
what is the passenger side sensor in the side of the head?
do i scrape paint off exhaust ports on heads from the rebuild?
Thanks!
Old Oct 19, 2005 | 01:25 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Passenger side is the fan switch, if you have a mechanical fan, then a pipe plug.
You don't have to, I've seen plenty of motors get exhaust bolted up with painted over ports (where the gasket surface is). Obviously you can if you want to ensure a proper seal.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
