Exhaust leak and MPG
Old Nov 18, 2001 | 11:47 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
can a really bad exhaust leak reduce your gas mileage by a big amount?
TIA
*89 Trans Am GTA
*Moderator at www.transamgta.com
To hell with the GM vs Ford war. We must unite, as brothers to fight the plague that is overtaking the world...RICE
Tony
Old Nov 18, 2001 | 02:31 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Exhaust leak that is before the Oxygen sensor can caouse the sensor to have an inaccurate reading; therefore, changing the signal to the ECM causing it to enrich the mixture.
I would not say you would notice a big difference in MPG. Myself i had an exhaust leak at the header flange (gasket like) for almost 1 year before I fixed it. What really pissed me off was not my MPG but anoyying exhaust leak sound and the fumes.
Hope this helps.
89Iroc, 305 TPI, WC T5, 3.08 Posi, Headers, Hooker Y-Pipe, 3 inch over the axle, Flowmaster 80, No Cat, Aluminium Driveshaft, Ported Plenum, Air Foil, K&N, AFPR, All free mods,
Old Nov 18, 2001 | 02:34 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
He is correct, exhaust leaks act as a "venturi" and pull outside air into the exhaust stream, and can fool the ECM that is lean via the O2 sensor.
I also know a person that ran on the dyno, then realized he had a header leak. Fixed the leak and gained 17 RWHP, dyno proven. I know I will probably get flamed for this, cause some people have a hard time grasping concepts, but it was from a trustworthy source. (P.S. it was not a stock setup)
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
my86bird
Oct 23, 2015 12:20 PM
rjcme
Sep 5, 2015 01:23 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
