backfiring thru the carb
Old Oct 23, 2005 | 05:09 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
i just got finished rebuiling my suspension and when i started my car up it decided to "backfire" up thru the carb. it sat for 3 weeks.
it idles rough but when i rev it up it "spits".
350 gw with msd ignition and holley 600.
thanks
Old Oct 23, 2005 | 06:12 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
I would check your spark plug wires, see if any of them are burned from hitting the headers. make sure they are all connected also. check to see if your distributor cap is wet. I had a prob when I did my carb swap and it was my timing. I would check that as well.
Old Oct 23, 2005 | 06:24 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Check your plugs as stated to see if they are fouled out. Check the ignition sysetm components . If they are good check you timing.
2012sergen11
Oct 13, 2015 07:38 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Damon
Sep 26, 2015 04:29 PM
lanceflame44
Sep 25, 2015 12:28 PM
RedLeader289
Sep 23, 2015 06:50 AM
