deleting EGR with HSR
Old Oct 24, 2005 | 12:35 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i will have to get rid of my egr with the hsr a couple questions...
1. should i just have a chip burned to "show" the car has no egr anymore ( i dont want to throw a code)?
2. and what should i do about the old egr soleniod and the vacuum lines attached to it?
also, off topic but simple...when filling your oildoes it make a difference what head you pour the oil into??
thanks!
Old Oct 25, 2005 | 12:19 PM
sellmanb's Avatar
Car: '86 Berlinetta
While I cant answer the HSR question. I can tell you that it makes no difference which head you put the oil in. It all drains back down to the oil pan either way.
Sorry I'm not much help lol.
Bump to the top
Old Oct 25, 2005 | 12:30 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
i would have the egr deleted from the chip as well as a performance upgrade PERFORMANCE RESOURCES can help you with your chip needs.as far as the the oil filler location as long as you can get the oil to the pan it does not matter the pump does the rest of the work......
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
