valve covers
Old Oct 24, 2005 | 09:51 PM
w1964bgta's Avatar
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
valve covers
will lt1 valve covers center mount fit g.m perf heads?
Old Oct 25, 2005 | 10:15 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Here's a quote from GMPP's site on the Fastburns:
This head has taller than typical rocker cover rails, providing exceptional clearance for rocker arms and valve train supports typically used in all out performance applications. The rocker rails are CNC machined for superior rocker cover gasket sealing. Front head faces are drilled and tapped for typical accessory drive bracketry. The Fast Burn head accepts both center bolt and early style four bolt flange mount valve covers.
Old Oct 25, 2005 | 10:18 AM
Ricktpi's Avatar
BTW LT1 covers are regular centerbolt.
Old Oct 26, 2005 | 05:35 PM
w1964bgta's Avatar
valve covers
Thanks Rick, I do remeber reading those exact words but I am unfamiliar with some of the terms and what they represent . Don't think me dumb just uninformed at the moment but am catching up fast on this site Thanks again for not berating me
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
