305tpi-350tpi
Old Oct 25, 2005 | 08:49 PM
Blkmaroman's Avatar
Car: 1998 zx9r
Engine: 899CC inline 4
Transmission: 6 speed manual
Axle/Gears: 15T front sprocket, 43T rear
305tpi-350tpi
My friend just got a 86 iroc with a 305 tpi but it smokes on start up and he has a 350 block laying around, can he take all the stuff off of the 305 and put on the 350 to put it in his car, there is no difference on the outside of the motor between the two, so i told him he could probably swap all the tpi stuff over to the 350 and drop it in.
Old Oct 25, 2005 | 08:53 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 305tpi-350tpi
Probably just valve stem change. $40.00 in parts, a few hours and you can change them out. While you have the valve springs off, spend a few buck and change them. Then your good to go.
Old Oct 26, 2005 | 08:27 AM
Blkmaroman's Avatar
Car: 1998 zx9r
thats what i thought but i didnt know if he would need bigger injectors or if he could use the same 305 heads on his 350 because thats what he wants to do to get more compression.
Old Oct 26, 2005 | 11:28 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
if you plan on doing any driving you will need to change the injectors and burn a new chip.
Old Oct 26, 2005 | 11:41 AM
Blkmaroman's Avatar
Car: 1998 zx9r
seems like it wont be too hard just unbolt and bolt back on with different injectors and chip, what about the cam.
Old Oct 26, 2005 | 11:44 AM
87zjeff's Avatar
does your friend know the origins of the 350? the cam has to be matched to the lifters. hydraulic to hydraulic, solid to solid,flat tappet to flat tappet, roller to roller.
Old Oct 26, 2005 | 05:24 PM
Blkmaroman's Avatar
Car: 1998 zx9r
its an old block like 70's, and he hasnt put it together yet so there arent any lifters or cam or anything in it yet, what would be the best cam for tpi 350
Old Oct 26, 2005 | 05:32 PM
87zjeff's Avatar
he will have to modify the intake slightly to get the intake to fit. the center 2 bolt holes are different i believe. a search should turn up some results on that.
as far as the cam, you will have to ask someone with more knowledge of cams than i have. i haven't done a lot of research on cams for non-roller type blocks.
Old Oct 27, 2005 | 08:10 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Check out Comp Cams website.. they make cams specifically for EFI applications like yours.
As far as converting 305 -> 350, you'll need to change out the knock sensor as well. You can't use the one from the 305 because the bore size is different. Different bore = different calibration. Get one for a 350.
