what is spark Knock?
Old Nov 18, 2001 | 03:11 PM
1986CamaroIROC-Z's Avatar
I am having a clickin sound in my engine, and people tell me it may be spark knock. What exactly is that, and what are the problems that come from it. How do test to see if it is spark knock? All responces are greatly appreciated since i am havin trouble here.
1986 Metallic Blue IROC-Z
80k miles, 305 TPI
Mods:
-Edelbrock Hi-Flow baseplate
-Dynomax Cat-back
-gutted MAF
-K&N's
-airfoil
-shiftkit
Old Nov 18, 2001 | 03:15 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by 1986CamaroIROC-Z:
</font>
does it make the clicking at idle? if it does, then it is not spark knock. i read your other posts. when you changed the oil and it got better, that would indicate an oiling problem. like another post said posiible collapsed lifter of at least clogged. because when you changed the oil it got better. an engine oil flush is an additive you put in the oil, run for 5 minutes and then drain and replace the oil and filter. it breaks down deposits.
Old Nov 18, 2001 | 05:01 PM
The clickin actually seemed to get worse now, and yes, it does happen in idle. U think this flush will fix the problem, if not im assumin some part is broken.
80k miles, 305 TPI
Mods:
-Dynomax Cat-back
-gutted MAF
-K&N's
-airfoil
-shiftkit
Old Nov 18, 2001 | 05:02 PM
rezinn's Avatar
A clicking sound could be from some component not being oiled properly or an exhaust leak. When does the clicking sound occur? Can you tell us the history of the engine?
Spark knock is when combustion happens too early because of too advanced timing or too low octane fuel, "knocking" the piston back. It sounds more like a thumping sometimes. Knocking typically wouldn't start happening out of the blue.
Also, have you noticed a loss in performance?
[This message has been edited by rezinn (edited November 18, 2001).]
Old Nov 19, 2001 | 06:16 PM
I do have an exhaust leak, but the car is dying when i try to start it, would an exhaust leak really cause the car to die, and for the tickin noise. The car ignition was redone in the summer, and at the time they told me i had it, its been tickin for a while, but was never so loud and it didnt kill the car when i start it. So i dont know.
Old Nov 20, 2001 | 04:10 PM
Yes, i have lost some power
80k miles, 305 TPI
Mods:
-Dynomax Cat-back
-gutted MAF
-K&N's
-airfoil
-shiftkit
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
efiguy
Sep 27, 2015 01:30 PM
