Cant turn motor over by hand
Car: 1986 IROC Weekend, Jetta VR6 Daily
Engine: 350 .030 over 5.7 TPI
Transmission: 700-R4 Rebuilt
Ok i just got done putting my remaned 350 in my camaro. Before hand i had it on a stand and had the pullies on and dampner on and could crank the motor over by hand with a wrench. Now with it in the car i cant. I removed the pulley b4 i put it in the car and when reasembling it i ended up striping the 7/16-20 thread out. i now have it taped for a 1/2 - 20 thread and a new bolt. Tried that but it seems lk im gona strip it out again. Any ideas what could be stoping it form roatatin? the head are on. no rockers. Tranny is in the car too. I found out i couldnt rotate it when i went to install torque converter. Im frecking out
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Heads are on, no rockers.
Don't use the balancer bolt to pull the pulley onto the crank. You'll just strip it out again. Use a proper installer.
plugs r out, yes i was turning it over on the stand with the heads on, i used an installer to put the dampner on.
Car: 84 z28
Engine: older 350, details unknown
Transmission: th350
Axle/Gears: factory limited slip
how much force are you putting on it when your try to turn it?
like does it just naturaly feel like its taking to much to turn it?
or could it be that you cant get the force behind it that you could with it on the stand
sorry im not a mechanic but ive remeved a few trannys in my day and know what your going through lol
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
